 Postato: 09 Gen 2014 alle 21:17
Postato originariamente da Dangerfield Ci sono problemi con la versione con caricatore 6cd?
l'audiolink normalmente sfrutta proprio il connettore del caricatore
Dov'è il posto più comodo per posizionarlo?
audiolink nel cassetto passeggero ed eventuale attacco per ipod nell'ultimo cassetto del tunnel...
Modificato da tipiaraldici - 09 Gen 2014 alle 21:17
 Postato: 09 Gen 2014 alle 22:15
andiamo per gradi.....
tu hai questa radio ?
 Postato: 09 Gen 2014 alle 22:28
ok
sul retro dovresti avere il connettore per il cd esterno
guarda qui:
ma soprattutto qui
 Postato: 09 Gen 2014 alle 22:37
@dangerfield
superfluo dire che prima di ogni azione devi togliere almeno il fusibile room
@andreone82
la grigia dovrebbe essere la 4H64 e queste sono le info
Double-DIN NB Bose Silver Audio System (4H64)
Description: This system includes a double-DIN head unit with an integrated AM/FM tuner and single-disc slot-loading CD player or in-dash 6-disc changer. The head unit has speed-sensitive volume control with three settings for top up and three more for top down. The head unit includes 4x25 (peak) Watt amplifiers, two of which are used for the door tweeters. Two other channels send speaker-level audio to a pair of single-channel 100-Watt amplifiers behind the unit for the special Bose door speakers. Mazda rates it as a "225-Watt" system. The double-DIN units are "modular", meaning that an integrated casette deck or MiniDisc player can be added to the bottom and the single-disc CD player can be swapped out for a 6-CD changer or MP3-CD player on top.
Markings: This unit looks like the previous 4H60, but has a silver/aluminum face and says "4H64" instead. It replaces the "AM" button with one marked "SAT". The head unit says "Bose" on it, as do the door speaker covers.
History: The silver systems were introduced in 2004.
Availability: All 2004 LS cars and the Mazdaspeed MX-5 came with this unit standard. An in-dash 6-disc CD Changer, MP3 CD player, MiniDisc player and Cassette Player are dealer-installed options
e per i my 04 questi erano gli equipaggiamenti audio
'04 base
Double-DIN Silver (?)
Door speaker (x2)
Windblocker speaker (x2)
'04 base with Convenience Package or Azure Blue Cloth Package
Door speaker (x2)
Door tweeter (x2)
'04 LS and Mazdaspeed MX-5
Double-DIN Silver (4H64) with Speed-Sensing Volume Control
Bose 100 Watt Single-Channel Amplifier (x2)
Bose Door speaker (x2)
Door tweeter (x2)
Bose Windblocker speaker (x2
Modificato da tipiaraldici - 09 Gen 2014 alle 22:41
 Postato: 09 Gen 2014 alle 22:42
Prima di tutto... l'autoradio è questa...
...non c'è scritto BOSE ma sembra lei
quel cassettino tra le due valvole è amovibile?... è un posto papabile per ospitare l'audiolink?
che fusibile???
Modificato da Dangerfield - 09 Gen 2014 alle 22:44
 Postato: 09 Gen 2014 alle 22:50
si il cassettino è amovibile, ed è tenuto in posizione da due "alette" a scatto sui lati corti.
essendo il radiolone "modulare" in quello spazio andava il modulo cassetta o minidisk.
i collegamenti tra i vari moduli avviene per contatti interni, di conseguenza, avendo tu il modulo principale e (sopra) il modulo lettore cd dovresti avere libero sul retro il connettore per il charger esterno (quello di destra)
il fusibile room (scatola portafusibili a sinistra del volante in basso) è l'ultimo in basso a destra (10A)
Modificato da tipiaraldici - 09 Gen 2014 alle 22:56
Da: RM, San Giovanni/Napoli
Da: RM, roma
